2017 Chrysler 300 S 5.7 Excessive wear on tires
Old Jan 28, 2020 | 11:48 AM
Usernamedray's Avatar
Default 2017 Chrysler 300 S 5.7 Excessive wear on tires
Purchased vehicle with close to 32,000 miles. Had on Ironman 2454520 about 8/32 all around. I took those off and put on Bridgestone Re980AS 2554520.
ive put less that 6,000 miles on them and they’re 6/32 and 4/32, I rotated once. I had the alignment done days after purchase and it was up to spec. I do have negative camber, but can that alone cause that much wear?? I’m going to replace both front control arms to adjustable in order to get camber up to spec. For the tears I’m going to change the control arm bushings.
any suggestions on anything? Can it be the minimal tire size change, and should I go back to stock size?
Old Jan 28, 2020 | 01:31 PM
REBEL59's Avatar
A 2017 model and bought with 32k miles already? You say the new tires have 6k miles but how many miles on the car itself by now? What kind of roads and load do you drive? And because I'm not that versed with the 300 line, is this an AWD model? and the tire wear primarily on the front tires and where is the wear(inner, outer, center tread areas or even across the tire?
Old Apr 3, 2020 | 04:24 AM
fadiks's Avatar
Mine are seeming to be like this after 14,000 miles. I'm hoping to need to supplant by 20,000. Ideally there will be some acceptable decisions in the stock 18" size. (please Michelin!)
ADKNV
May 12, 2015 11:28 AM
hotrodn93l
Dec 27, 2009 07:50 PM
indept
May 4, 2009 04:42 PM
Skycop385
Nov 15, 2008 07:43 PM
branham0917
Nov 11, 2008 07:59 PM
