2102 chrysler 300 limited not running.
Old Feb 18, 2020 | 03:56 PM
Brent Samuels's Avatar
ok any codes in the computer that you know of? did you check for blown fuses ?
Sorry for the late response. I looked for blown fuses. I found that I was missing a 10a security fuse and a 25a transmission fuse from looking at my life of the fuse box. I checked the fuse for the fuel pump the fuse wasn't blown. I did put in the others now the car says I need to service transmission take it to the closest dealer auto park was disabled. And the car won't cut off I have to disconnect the battery. My wind shield wipers are on even tho they are off on the sticks. They continue to go until the battery is unplugged or I take out the fuse for the wind shield. I'm stumped. They never said anything about a transmission issue.. the car didn't either until I put in the 44 fuse for the 25a transmission. I removed the fuses that I put in but the code still pops up. I out 5 gallons in the gas tank but the car says I have low fuel...
Old Feb 24, 2020 | 04:17 PM
This is from the dealership. This is what they said was wrong. Obviously needs more than a computer and fuel pump.
Old Feb 25, 2020 | 07:13 PM
so looks like you need a better scanner then a simple obd2 code reader tow it to a different shop that has good scanners see what other computers they cant talk to.
Old Mar 3, 2020 | 03:15 PM
Okay I will have to try that I got the fuel pump to work . The one they sent me had different wiring configuration I had to swap two wires. Now I just need to clear the auto park disable message and the transmission error says the car isn't in park but it is I can't push the car. Won't let me try and start the car because of the errors. If I take it to a shop can a reader clear the faults so we can try starting it? If that's the case I can go rent a car trailer and to it myself to another shop.
maintenance
Apr 30, 2015 05:15 PM
Mama2Saigai
Jul 24, 2013 01:46 PM
smokeydog
May 8, 2010 10:20 PM
moose7171
Jun 4, 2008 04:59 PM
JasonB
Jul 6, 2007 12:00 AM
