300m quick learn or re-learn
Old Jan 16, 2008 | 09:45 AM
Spoon's Avatar
Default 300m quick learn or re-learn
can anyone post procedures for re-learning engine and transmission for an 02, 300m 3.5liter
Old Jan 16, 2008 | 01:55 PM
moe's Avatar
moe
Default RE: 300m quick learn or re-learn
has to done with dealer tool called "drb"
Old Jan 21, 2008 | 09:33 PM
MikeHTally's Avatar
There's no PCM reset like in the newer LXs or the Rams?
Old Jan 22, 2008 | 11:48 AM
moe's Avatar
moe
you can try disconnecting battery,for aleast 3 mins or longer this will put modules to sleep and will have to relearn the values all over.
Old Nov 1, 2017 | 01:41 PM
jaded13640's Avatar
Not to hijack the thread or anything but I'm in a similar situation. I replaced the range sensor in the trans of an 07 town and country and the instructions said that any service or replacement of the valve body may require a "quick learn". I assume we're talking about pretty the same process. I have a hand held scanner but I do not have a high end unit like a Mac or Snapon etc. I know sometimes there's a way around this stuff such as "oh, yea, you just turn the key on and off three times and hold your mouth right while hitting the brake pedal etc" LOL. Since all I have is a little hand held "code reader" for the most part, I'm sure I'll need a real scanner to do it, if it can be done without the "DRB" that moe mentioned.
Hopefully if I get an answer to my question it will help the OP with his issue.
Thanks in advance,
Wayne
Old Nov 1, 2017 | 04:03 PM
tarhealcracker's Avatar
I'm glad you are getting some help here but aren't you in the wrong forum?
Aug 19, 2011 09:39 AM
BigBlocksnHardrock
Apr 7, 2007 12:19 PM
Nov 14, 2006 06:47 AM
icatfishman
Sep 25, 2006 04:21 PM
Dodgegirl19
Apr 15, 2005 04:57 PM
