asd relay clicking,no crank,help
Old Mar 22, 2015 | 09:17 AM
mraircraftdr's Avatar
Default asd relay clicking,no crank,help
99 300m no crank,asd relay clicking,checked for a code,didn't get a actual code number but the scanner said ,,,,single board engine controller communication bus failure, ,has anyone here seen this or knows what it means,,I replaced the pcm a yr ago(aftermarket),any info would help,,thanks
Old Mar 22, 2015 | 01:31 PM
possible pcm possible wire issue the BUS is a commutation network to allow all the computer to talk to each other.
Old Mar 22, 2015 | 04:52 PM
Correct,I understand what the bus does,I did get a schematic of the wiring and unplugged every sensor and switch involved w that com connector,yet the relay continues to click,I'm wondering if it would be worth a few bucks to hit a junkyard and pickup a use pcm and plug it in just to see if the clicking goes away,
Old Mar 22, 2015 | 08:23 PM
do you have a gray key?
Old Mar 24, 2015 | 06:39 PM
Yes I have two and both do the same thing,,I would think if I had a skim issue I would get e code though
Old Mar 25, 2015 | 08:47 AM
prob the pcm is faulty it is a remain unit. and unless you have a real good scanner things like a skim code will not show up.
dna9656
Mar 29, 2018 11:48 AM
mraircraftdr
Apr 27, 2015 10:37 PM
boosky
Jun 12, 2013 08:09 AM
irdaneel
Feb 21, 2012 10:38 AM
LisaG
Aug 27, 2009 09:14 AM
