ATF+4 or 8&9 Speed ATF transmission fluid?
Old May 12, 2023 | 10:52 AM
jgronberg@sbcglobal.net's Avatar
Default ATF+4 or 8&9 Speed ATF transmission fluid?
I have a 2015 300 V6 automatic transmission. Which transmission fluid is correct for this transmission? Thank You.
Old May 12, 2023 | 09:14 PM
Atf + 4
Old Jul 14, 2023 | 04:30 PM
Thank you for responding. After much research it seems that Valvoline MaxLife and ATF+4 are the most talked about on the various chat lines to use for Chrysler 300 transmission fluid.
Can you explane the differences between the two.
Thank you.
Old Jul 15, 2023 | 10:17 AM
ggoose's Avatar
I believe the 8-speed transmission was the only trans available on the 2015 300. Use 'auto-shift' to confirm. While driving at highway speeds, put the shifter into auto-shift. The PRDNL display should show a boxed number. Bump the shifter to the '+' and the number should increment. Keep bumping until the number no longer increases. If you see 7 or 8, you have the 8-speed.
As for fluid, do not use universal fluids. Use the manufacturer specified atf only, licensed ZF only. Note it is expensive.
mrls430
Mar 27, 2024 05:14 PM
Zweifel
Oct 10, 2020 11:22 AM
Fayraz
16
Jul 30, 2014 08:44 AM
sebring01
Aug 27, 2007 06:07 PM
sebringpilot
Nov 7, 2006 03:52 PM
