Fluid or oil leak
Old Nov 22, 2020 | 09:28 AM
keithm's Avatar
Default Fluid or oil leak
I have noticed an oil leak after a long drive (50 miles)
Closer inspection has revealed it is all over the bottom of the engine I’m seeing signs of it around the trans cooler block where the lines snap in but it seams more pronounced on the opposite side of the cooler If I understand it correctly the top third is trans cooler the fluid could be migrating but it’s a lot of fluid or oil on that side The other thing is it’s looks like motor oil but there is no oil cooler so it couldn’t be oil On the other hand if it trans fluid it’s in bad shape I thought I’d install an external trans cooler And change fluid and filter in trans I’m a little nervous about that, did that on a Ford one time and it killed the transmission Any thoughts or opinions
Would be greatly appreciated
Old Nov 22, 2020 | 10:02 AM
ggoose's Avatar
Year, mileage, and engine
If you use a white paper towel and wipe up oil in spots you may be able to see its color and make a determination of what type pf fluid. One issue with oil and motors is the air currents swirling around the engine compartment that makes locating an oil leak challenging at best. To determine the source you may need to clean off the engine (being mindful of electrical connectors, etc).
Old Nov 23, 2020 | 12:21 AM
Icarus's Avatar
3.6L oil coolers are famous for leaking...
Old Nov 24, 2020 | 05:06 AM
keithm's Avatar
Sorry forgot 2006 300c 5.7 I’ll give the paper towel a try
Jm2007
Jul 12, 2016 09:08 PM
zach92
Feb 9, 2014 07:55 AM
NeonOn19s
Feb 21, 2011 10:34 AM
sidhabo
Aug 21, 2009 11:08 PM
bill6047
Jul 3, 2008 09:17 AM
