Gas Fill up problem
Old Jun 26, 2011 | 11:49 AM
Harveyd's Avatar
Default Gas Fill up problem
I have a 2006 Chrysler 300 touring and when you take it to fill it up the gas pump cuts off as you try to fill it.I have to put in a little at a time until it fills up???
Has anyone come across this issue
Old Jun 26, 2011 | 12:20 PM
Djinn-n-Tonic's Avatar
Yes..Its a common issue on 300/magnum/Charger Models. Your vehicle uses what is called a "SADDLE" tank, which is actually 2 seperate Tanks in One housing. It uses a Syphon Method to fill both halves of the tank......But unfortunately, It doesnt syphon over Fast enough. The remedy is to ....WAIT IT OUT.....I know Its a poor excuse for a fix, but There is Nothing that can be done to remedy the situation.
Stay tuned, I'll try and get the service Bulletin for ya.
Old Jun 30, 2011 | 10:48 AM
blacknight's Avatar
Originally Posted by Djinn-n-Tonic
Yes..Its a common issue on 300/magnum/Charger Models. Your vehicle uses what is called a "SADDLE" tank, which is actually 2 seperate Tanks in One housing. It uses a Syphon Method to fill both halves of the tank......But unfortunately, It doesnt syphon over Fast enough. The remedy is to ....WAIT IT OUT.....I know Its a poor excuse for a fix, but There is Nothing that can be done to remedy the situation..
^^^What he said is correct.
The other option is to not fill as fast.
On the gas handle, there's usually three selections, slow, medium & fast
Most attendants will put the selector on three--or the fastest fill.
You can put the selector on medium or slow and it should be fine. It will just take a little longer to fill up
Old Jul 31, 2011 | 06:02 PM
Harveyd's Avatar
I have done it slow also.Thank you all for your wonderful advice
Old Feb 3, 2012 | 06:58 PM
Harveyd's Avatar
Any new issues with this
Old Mar 26, 2012 | 12:08 PM
BossLady's Avatar
Lift the back of the gas pump gun up instead of letting it rest on its own. I have no issues when I do this.
kschanna
Jan 1, 2018 04:38 PM
skid2964
Jan 6, 2012 03:12 PM
Moosetrax311
Jan 4, 2012 05:07 AM
Mr Goodwrench
Dec 29, 2011 09:27 PM
wrenchnet
Aug 15, 2011 02:01 PM
