Help please!-2007 300 Touring
Old Jan 5, 2020 | 03:57 PM
Dbuck's Avatar
Default Help please!-2007 300 Touring
Hello all,
I have a 2007 300 Touring with 100k miles on it. When the temperature is cold outside( 45 degrees or less) the car starts fine and then the ECT, electronic throttle control light (red lightning bolt) comes on. The car usually starts to hesitate and accelerates poorly. Sometimes it won’t respond at all when the gas pedal is pushed. I can usually pull over, turn the car off and restart and it goes back to normal, no light. It runs well once warmed up. I took it to one mechanic who couldn’t do anything with it. Any ideas? Is this something that would be better to let a dealer look at?
Thank you for the help!
D
Old Jan 5, 2020 | 07:43 PM
what are the codes in the engine computer for the issue?
Old Jan 6, 2020 | 06:54 PM
Dbuck's Avatar
I don’t have a computer to check codes. I’m reading more and this doesn’t seem to be a rare problem. Some have said there’s a way to reset the electronic throttle control? I appreciate anyone’s help that has dealt with this.
Old Jan 7, 2020 | 08:35 PM
just resetting something like that wont help. If you do that you also erase any data the computer has stored to help correctly locate the issue.
Old Jan 8, 2020 | 06:57 AM
tarhealcracker's Avatar
DEBUCK Some auto parts stores will read your codes for free. Check it out in your area.
Old Jan 17, 2020 | 07:20 PM
Dr.Dodge00's Avatar
Sounds to me like a throttle body issue.
Head to your local Autozone and check for error codes in the computer at no charge.
Jeff
Edgewood
Feb 15, 2018 03:05 PM
77300
9
Feb 11, 2017 07:24 PM
Bigdave757
Oct 18, 2015 09:22 AM
Bill Houck
May 8, 2013 08:56 PM
azzwoopa05
May 10, 2007 08:37 AM
