Limp mode Issues - Please Help
Old Jul 24, 2021 | 05:10 PM
manoowar2's Avatar
Default Limp mode Issues - Please Help
So this has been a long-time issue - 2005 - 300C - 5.7L - 94K
.The first instance happened as I was driving a back road, was at a stop, stepped on the pedal: limp mode red lightning bolt and the ESP BAS lights lit up - Turned off the car, restarted, worked for 10 mins, repeat
The car starts up - drive for 20 mins - back to limp mode
The only upgrade to date - Legmaker CAI, Strut tower Brace, and Headlights.
Cleaned the throttle body then replaced, completed the reset - same same
Next was the ECM - Got one (3weeks to locate) - programed by dealer - same same
Replaced Mass Air Flow Sensor (Non-MOPAR), Pedal Sensor, Wiring harness. - Same same -
About to purchase an engine harness - Still not sure if this will fix the issue
Hoping for a lil help here
Got the following codes:
P0113 Intake Air Temperature Sensor 1
P2101 Electronic Throttle Control Motor Performance
P2118 Electronic Throttle Control Motor Current Performance - Bank 1
P2110 Throttle Actuator "A" Control System - Forced Limited RPM
P2111 Electronic Throttle Control System - Unable To Close - Bank 1
Adding picture
Old Jul 25, 2021 | 10:57 AM
ggoose's Avatar
year - model - engine - mileage please
Old Jul 25, 2021 | 11:07 AM
manoowar2's Avatar
My apologies - 2005 - 300C - 5.7L - 94k
Old Jul 27, 2021 | 09:48 PM
Used or new throttle body? and the 5.7 does not have a mass air flow sensor so what did you replace then? Do you have a scanner that can move the motors on the throttle body or look at the voltages when it goes into limp in ?
Old Jul 27, 2021 | 10:04 PM
manoowar2's Avatar
Thank you for the reply - The TB was replaced with a NEW OEM TB after the NON- Mopar TB was having the same issue; mass air flow sensor was replaced. I don't have scanner
Old Jul 29, 2021 | 11:15 AM
CHRYSER DOES NOT USE MASS AIR FLOW SENSORS. Show me the item you replaced. If you dont have a scanner then how did you relearn the app voltages in the computer to the new part?
Old Jul 31, 2021 | 12:22 PM
manoowar2's Avatar
New Mopar throttle body. I misspoke on the mass air flow sensor- - its Intake Air Temperature Sensor - Asking the mechanic on the other.
Old Aug 1, 2021 | 10:46 PM
manoowar2's Avatar
P2110 Throttle Actuator Control System
5V
Old Aug 5, 2021 | 05:34 PM
Did the tech perform a throttle body relearn with a scanner?
Old Aug 6, 2021 | 12:01 PM
manoowar2's Avatar
Yes - Same issue - rescanned got code - P2110 Throttle Actuator Control System
Executing the following troubleshooting steps
Replacing or cleaning ABS sensor
Replacing or cleaning EGR Valve
Is there anything I should be looking for? Almost thinking to replace all the sensors
Edgewood
Feb 15, 2018 03:05 PM
Simpleman
Oct 18, 2017 11:52 PM
amen.ak
Jul 24, 2016 01:44 PM
Bill Houck
May 8, 2013 08:56 PM
profbob
Nov 4, 2010 07:32 AM
