Problems with my AC.
Old Jul 14, 2018 | 05:13 PM
thrower65's Avatar
Default Problems with my AC.
I have an 07 300 touring and I've been spending all summer trying to get the ac to blow cold. I tried using one of the stop leak garbage things from Walmart and it didn't work. So I took it to someone to get it vacuumed and charged. Everything seems to be working, but the car won't take the refrigerant. We noticed that smaller radiator fan doesn't turn on when the ac is turned on. However, the fan will turn on when the car gets hot and it doesn't overheat. What could be causing this?
Old Jul 16, 2018 | 11:40 PM
Was he ale to vac out any in the system? and stop leak could have easily clogged up alot of things
Old Jul 17, 2018 | 11:33 AM
thrower65's Avatar
Yes he vacuumed everything out, but it won't accept anything.
Old Sep 10, 2018 | 10:01 PM
Killavolt's Avatar
is the compressor running? do you have a gauge manifold set to determine the pressures properly?
The system won't charge if the compressor isn't running
Redblade13
Jul 21, 2018 01:25 PM
pacifica/04
Jul 17, 2015 09:30 PM
2002SebringOwner
Jul 29, 2013 05:32 PM
Mumof4
Jul 15, 2013 06:48 AM
maddhatter
Apr 10, 2012 10:01 PM
