Rear door latch broken. Unable to open the door to replace it.
Old May 5, 2012 | 06:29 PM
provench's Avatar
Default Rear door latch broken. Unable to open the door to replace it.
From time to time, onr of the rear door refused to unlock. I removed the rear door latch to clean it but saw it was stuck in corrosion. I reinstalled it making sure it was in the unlock position planning to buy a new latch assembly shortly. I probably screwed it trying to clean it or didn't reinstalled it properly cuz I cannot open the door anymore. You see my problem...I need to open the door to replace the latch but can't open the door...Looks like I paint myself in the corner.
-I hear the solinoid toggleling when trying to unlock
-The unlocking button moves up and down
So, the problem seems to be in the latch refusing to unlock. Anybody has any idea what I could do to solve my problem without having to destroy the door panel?
Old May 6, 2012 | 05:56 PM
replace the door lock actuator
Old May 7, 2012 | 07:34 AM
provench's Avatar
That's what I want to do. My problem is that I cannot open the door to access the actuator.
-How to access the actuator without opening the door or how to open or remove the door that refuses to unlock?
BTW, I forgot to mention that this is a Chrysler 300 2005.
Thanks for your help.
Old May 7, 2012 | 12:26 PM
ChryslerCares's Avatar
The instrument cluster locks or unlocks the doors when an actuation input signal from a door lock switch or Remote Keyless Entry (RKE) transmitter is received. The instrument cluster turns on the output drivers and provides a voltage level to the door lock motor for a specified time.
Turn the ignition off.
Remove the doors inner trim panels to gain access to the door latch connector.
Disconnect the Right Door Latch connector.
Disconnect the Instrument Cluster C1 connector.
Measure the resistance of the (P392) Door Lock Driver Right Doors circuit between the Cluster C1 connector and the Right Door Latch connector.
The door lock motors are controlled by the instrument cluster. A positive and negative battery connection to the two motor terminals will cause the motor to move in one direction. Reversing the current will cause the motor to move in the opposite direction.
Old May 9, 2012 | 07:43 PM
provench's Avatar
Thanks.
I will check this out and let you know.
Old May 9, 2012 | 10:43 PM
TNtech's Avatar
The easiest way to get the door open without breaking the door panel is to get a locksmith to open it with a "slim jim" or whatever he has. You MAY be able to flex the top of the door panel out enough to grab the lock button and pull up on it...that is if the actuator isn't jammed so you can't pull on it.
Old May 13, 2012 | 11:25 AM
provench's Avatar
Yeah...It may be my best option.
Thanks.
Old Oct 7, 2021 | 04:42 PM
Nathancase1's Avatar
What do you do if the actuator is not working?
aggiejet
Oct 17, 2022 05:56 PM
mbaker
Jan 18, 2012 01:31 AM
GeneralDisorder
Jun 4, 2010 01:18 PM
joeuc23
Oct 28, 2007 11:10 AM
chase950
Cirrus & Breeze
Sep 23, 2007 12:15 PM
