Repalced battery - uConnet won't turn on and blind spot disabled
Old Aug 11, 2025 | 09:31 AM
300S_Mass's Avatar
Default Replaced battery - uConnet won't turn on and blind spot disabled
Hello,
I have a 2017 300S. Had an issue where there was enough voltage to power the vehicle, but it would not start the engine. I went ahead and replaced the battery (dated 2019), and now the uConnect system will not turn on (radio, camera, etc), and the display notifies me that the blind spot markers are temporarily disabled (just stay lit up within the side mirrors). The check engine light was on, but it's gone away. I've started and driven it a bit now, thinking the computer would be reset, and it might clear itself up, but it hasn't. I have an OBD II pocket scan; I thought I would plug it in and see if anything was left over from the minimal voltage before replacing the battery. I was also going to check fuses.
Thanks for the guidance!
Old Aug 11, 2025 | 10:32 AM
300S_Mass's Avatar
Update - disconnecting the negative terminal on this newly installed battery has allowed for the uConnect system to power on, and for the blind spot markers to become "enabled". Now, have to resolve the matter of no volume coming out of the system (radio, Bluetooth device), and hopefully will be back to 100%.
Old Aug 13, 2025 | 11:45 AM
tarhealcracker's Avatar
It could be you did not get a complete reset on your system. Disconnect the Neg terminal (like before) but this time hold it to the Pos terminal for 10 seconds. Be double damn sure it's the Neg terminal you are disconnecting. Okay ?
Do report back to us.
Old Aug 14, 2025 | 06:52 AM
300S_Mass's Avatar
Originally Posted by tarhealcracker
It could be that you did not get a complete reset on your system. Disconnect the Neg terminal (like before) but this time hold it to the Pos terminal for 10 seconds. Be double damn sure it's the Neg terminal you are disconnecting. Okay ?
Yes, that's what did the trick (disconnecting the neg). Interesting because the backup camera and radio volume were the last bits to properly "come back" but everything is working as it should be.
Old Aug 14, 2025 | 01:19 PM
All's well that ends well. Many thanks for getting back to us.
teddysmith1952
Nov 19, 2018 09:43 AM
Gazdon
Mar 23, 2018 08:34 AM
miki75
Dec 16, 2010 07:31 PM
jds8535
Dec 21, 2009 04:39 PM
Cantona
Oct 10, 2009 08:19 PM
