Could it be the battery??
Old Oct 10, 2009 | 03:40 AM
Cantona's Avatar
Default Could it be the battery??
In the last 2-3 weeks my 3.3l grand voyager has lost the radio code and has struggled to start about 3 times ,once its started its fine I was thinking could the battery be dying a death and if so what sort of power output should I be looking to buy . UK owner.
Thanks.
Old Oct 10, 2009 | 07:25 AM
baldboab's Avatar
Hi, I aint a mechanic but I suppose it could be the battery. One way is to get the battery checked. If you drive to any Halfords store they will check it for you. They did checked mine for free while it was in the car. Of course they are looking to sell you one so have a look at the reading they get yourself.
I would be grateful if you could let us know what it turns out to be.
Thanks.
Robert.
Old Oct 10, 2009 | 08:02 AM
22chrysler's Avatar
all u need to check your battery is a simple volt meter. a charged battery needs to be 12.6 volts. while cranking it cannot drop below 9.6 volts. simple check to see if its your battery or some other problem
Old Oct 10, 2009 | 09:16 AM
u can also get 12.6v and less then 300 amps and the van not start or turn over real slow.
Old Oct 10, 2009 | 08:19 PM
22chrysler's Avatar
but as soon as u put a load on a sub par battery the voltage crashes. 9.6v is bar minimum during cranking. when u load a bad battery, even though open surfact voltage reads acceptable, as soon as you load it it dropps below 9v it's junk. and fyi a battery @ only like 12.3v is considered only 50% charged.
1baddturbo
Jul 1, 2008 10:03 PM
May 14, 2008 08:54 PM
sebringgirl2000
May 5, 2008 08:09 AM
Jun 26, 2007 06:55 PM
Ben
Sep 19, 2006 07:44 AM
