Replaced all 4 o2 sensors still throws codes saying their bad
Old Sep 29, 2025 | 02:35 PM
Fubar716's Avatar
Originally Posted by FIREM
Fuel pump pressure and volume testing would confirm proper troubleshooting and pass or fail the component. …….
I’m guessing
thanks, that’s going to be next thing to test, I’ve about ran out of parts to replace so bound to hit it soon
Old Sep 30, 2025 | 09:24 PM
What were the original O2 sensor codes you got before replacing them?
Old Oct 1, 2025 | 07:58 AM
ggoose's Avatar
What are the current diagnostic codes? As previously noted, circuit high (high resistance) indicates an open circuit, e.g. broken wire, or a bad ground. Since the system stays 'open loop' indicates the O2 sensor heater circuits are not getting power/not working and not allowing the sensor to heat up and go to 'closed loop'. All 4 O2 sensors showing high indicates a common/single point which may be the ground.
A failing fuel pump would not cause an O2 circuit high code.
pishta68
Feb 3, 2025 05:19 PM
Joryk
Sep 29, 2021 03:51 PM
toyota
Jul 31, 2021 10:52 PM
momzilla
Jan 26, 2018 08:47 AM
SpudlerT+CTouring
Dec 13, 2011 12:20 PM
