Tachometer making noises after AC belts replaced
Old Jun 23, 2014 | 09:59 PM
luked2's Avatar
Question Tachometer making noises after AC belts replaced
The A/C and ACCE belts on my 2004 300M broke. Picked it up this evening and now the tachometer is making strange noises. There was NO issue with the tach before the repair work. What could be causing this?
Thanks for any guidance you can offer.
Old Jun 24, 2014 | 12:52 AM
Tachometer as in inside the car where the cluster is?
A belt repair would not have a single thing to do with it Id check the noise else where. Plus a tech is highly unlikely to make any noise.
Old Jun 24, 2014 | 09:35 AM
FIREM's Avatar
Check to see if the hood release cable is rubbing on the alternator pulley.
Should be routed to a clip on the upper rad support but have seen them rub on the alternator.
XSIV8
Jan 28, 2014 10:13 PM
MarcoG
Jul 2, 2012 02:37 AM
stew88fan
Apr 15, 2011 04:18 PM
dubs0587
Sep 19, 2010 11:31 PM
brad
Nov 21, 2006 06:40 PM
