xenon lights
Old Aug 9, 2011 | 03:43 PM
DKAVOUL's Avatar
Default xenon lights
The lights turn off and on again
Old Aug 11, 2011 | 11:52 AM
blacknight's Avatar
Care to be a little more specific
What type of car (base, touring, C, SRT8)
What do you mean turn on/off?
Do they flicker?
Does it happen when you hit a bump?
Do you have a system in your car (aftermarket radio/amps)
Do you have factory HID's or aftermarket?
Old Aug 12, 2011 | 03:38 AM
DKAVOUL's Avatar
You are right, not enough information.
2006 300C(EUROPEAN) meaning 2.7 l engine, all extras.
The lights are on and suddenly one or both is turned off by itself. Most often they turn on after 10 secs but this can go on for long. They do flicker a little bit before turning off. It is not connected with bumps. I do not have any aftermarket system in the car and the HIDs are factory.
Thanks.
Do they flicker?
Old Aug 12, 2011 | 07:58 AM
blacknight's Avatar
When you say the HID's are factory, I can assume they came with the car direct from the manufacture,
Old Aug 12, 2011 | 10:19 PM
DrGadget's Avatar
Sounds like the ballasts are failing and being a 2006,its likely.
Old Aug 13, 2011 | 10:11 PM
TNtech's Avatar
Could be. Not often they both go at the same time but it's possible. Could also be an IPM power feed issue.
Old Aug 14, 2011 | 05:34 AM
DKAVOUL's Avatar
Yes that is correct.
Old Aug 14, 2011 | 05:36 AM
DKAVOUL's Avatar
Thank you very much
Old Aug 14, 2011 | 08:25 PM
DrGadget's Avatar
yeah,your right!I didn't notice that it was both "lights"
sonic gihad
Jan 27, 2009 08:29 AM
halo589
Sep 16, 2007 03:57 PM
cdyer11505
Mar 10, 2007 11:50 AM
sshbou
May 2, 2006 07:10 PM
omegahahal
Nov 2, 2005 12:54 AM
