09 Air intake options
Old Feb 26, 2010 | 09:41 AM
conversion02's Avatar
If you MAF or TB is getting oiled up, you're using WAY too much oil. I've had K&Ns on many cars and done many cleanings of the filters and never once had a problem...even on a 4.6 DOHC T-bird with a 9 lb blower.
Old Mar 12, 2010 | 12:46 PM
95Jersey's Avatar
Originally Posted by scottman70
I would highly suggest that you DO NOT use a filter that requires oil to filter the air. I installed a K&N on 2 vehicles and within 2 years I was having fouled sensors from the oil on 1 of my vehicles. The other vehicle I tore apart the air tube and it was slightly coated with oil and some dirt. Go with the dry only, that way you will never have the issue with the oil fouling the sensor in the intake tube! I never over-oiled mine either I was very careful to use very little oil but it still gets through! I am not the only one that has had this issue with there vehicles, I have heard tons of opinions stating the same thing! I learned the hard way though!
Then you are over oiling your filter. They only need a quick spray with a single pass. you should be able to hold the filter in your hand without any excess dripping of comming off in your hand. You just need a light enough spray to capture dirt and that ain't much.
onebad300C
Feb 21, 2007 01:27 AM
advans
Dec 26, 2006 10:45 PM
fdfever
Dec 6, 2006 07:35 PM
fdfever
Oct 14, 2006 06:28 PM
al
Jun 23, 2005 02:56 PM
