2007 Chrysler Aspen Cold Engine Clicking Noise
Old Feb 13, 2011 | 09:14 PM
joeboy's Avatar
Default 2007 Chrysler Aspen Cold Engine Clicking Noise
2007 Chrysler Aspen 5.7liter Hemi\r\n
When I start the vehicle and it is cold, I am hearing a clicking noise as the engine idles and once I start to drive the noise increases as I accelerate. Once the engine is warmed-up and i drive for a few minutes the clicking noise then goes away. Any advice!
Old Feb 13, 2011 | 09:39 PM
Djinn-n-Tonic's Avatar
If one of the other techs can come up with it...I seem to recall a bulletin for 4.7 and 5.7 exhaust manifold stud breakage. Very common to Durango and Dakota, But Im not sure if the ASPEN fell into that boat or not, and I cant seem to find the bulletin at the moment.
Very easy to check......Immediately after cold start, listen at the left and right front wheel wells.......and have an assistant tap the throttle.....If this is the case...It will be painfully obvious..
Old Mar 7, 2012 | 08:26 PM
Armandol's Avatar
I have the same problem on my aspen... 2007 Hemi V8 5.7 liter.
Old Nov 12, 2012 | 01:49 PM
IlluminatiAspen's Avatar
Default Clicking sound
My mechanic claims the clicking sound is caused when oil drains out of the heads (he claims happens to most fords and dodge trucks/suvs) each time the engine is shut off, because of thier design. Basically the clicking you hear is the sound of dry heads rubbing on the inside of the combustion chamber. Once the engine starts oil lubricates the chamber and the clicking ends. (I am not a mechanic or a grease monkey so I take no responsibility for use of improper terms in the above description).
Old Nov 8, 2017 | 01:29 PM
teyhall's Avatar
Any resolution to this issue? I am experiencing this with my 2007 Chrysler Aspen (5.7 HEMI) also. Getting different information from each shop that sees it. The dealership told me its normal bc of the lifters. The sound is awful! Cannot be normal.
Old Nov 9, 2017 | 10:30 AM
Armandol's Avatar
Yes, the fix was the replacing the gasket in the exhaust manifold.
Old Nov 12, 2017 | 02:36 PM
Canadian_Apen_ Owner's Avatar
This an be quite a lengthy job, as the manifold bolts have a tenancy to shear, I changed the gaskets and heat shields on my 20075.7L Hemi Aspen this summer. Do lots of research on Youtube before you start.
Old Nov 22, 2017 | 06:34 AM
billdc's Avatar
This is what happened to mine. Clicking for 30-90 seconds after cold start. The manifold bolts had to be replaced and some were sheared off. I don't remember the cost but when the mechanic described everything in the way, it seemed worth it. It has not occurred since.
kfallsdad
Oct 14, 2020 12:04 AM
jesusayalajr2007
May 13, 2014 05:24 PM
PEDROCCOTA
Apr 8, 2010 10:22 AM
nightingales
May 11, 2009 09:04 AM
nortcheez
Jan 13, 2006 03:03 PM
