Aspen 2007 overhead console
Old May 24, 2020 | 05:59 PM
RickD's Avatar
Default Aspen 2007 overhead console
The led lights on my 2007 Aspen overhead console do not turn off! Can anyone tell me how to remove the console? Has this happened to anyone?
Rick
Old May 25, 2020 | 12:53 PM
calamity coyote's Avatar
I'm guessing you are talking about the dome "Spot" LED lights that you push in to turn on/off. Yes, I have had them stick before. I just keep messing with them until they turn off.
As for removing the overhead console, their are 4 very strong clips that hold it up in to the headliner. What I have done is open the sunroof so you can get up in there. Pull back the rubber seal which is holding the headliner up to the metal roof panel. This just slides off and slides back on after. Once you remove this seal, you can gently pull the headliner down to see up in there. The two clips towards the back are easy to see. Carefully pull the console down while pushing on the clips. The two towards the front are a bit more difficult. I think they also clip in to the roof metal. You will have to carefully pull down the front to get them to "pop" out. May even try getting a wide flat head screwdriver in there. Just be careful not to put too much pressure on the headliner as you don't want to mess that up.
Old Jul 13, 2020 | 03:27 PM
I just created a DIY post on removing the console and options for fixing the light.
https://www.chryslerforum.com/forum/...44/#post115045
rswolff
Jun 20, 2018 08:30 PM
kwad
Nov 17, 2015 03:16 PM
gmullen
Jun 26, 2011 02:17 PM
kevinc
Oct 21, 2007 10:25 PM
pyron02
May 16, 2007 11:42 AM
