Automatic Transmission Fluid Level
Old Jun 5, 2012 | 03:50 AM
sea doo's Avatar
Default Automatic Transmission Fluid Level
Hi,
I have a problem with the transmission oil level. Regardless of temperature of the engine or the ambient, oil is always at the same level between HOT and COLD holes. In the garage I have a temperature of about 20°C (68°F), the car is from 2 days not ridden and oil is at the same level as in the picture.
Should I drain the oil, (once I did it, because when the engine was cold, oil was above HOT hole) ?
I think the previous owner had to pour the oil.
Is the fluid level will be too low, the EVIC will show me some message or warning light about transmissions fluid level?
Thanks.
Old Jun 5, 2012 | 08:39 AM
TNtech's Avatar
Are you checking it in Neutral?
Old Jun 5, 2012 | 11:58 AM
sea doo's Avatar
Oh, thanks, my mistake, I checked only in the Park.
The fluid level is correct.
Thanks for the reply.
Old Jun 12, 2012 | 08:31 AM
aggiejet's Avatar
Are you implying that you should check the level while in neutral? According to my owners manual in should be checked in Park.
4. Place the gear selector momentarily in each gear position ending with the lever in P(Park)
Nuieve
Oct 29, 2013 04:37 AM
alexnz
May 16, 2012 02:00 PM
tommymca79
Apr 11, 2012 05:59 AM
berlina
12
Jun 17, 2011 02:06 PM
kjenkins1979
Mar 19, 2009 10:53 PM
