Beyond confused ...need help
Old Jun 2, 2017 | 08:31 PM
Unforgvn1200's Avatar
Default Beyond confused ...need help
I have a 2007 chrysler aspen with the 5.7l. After getting it we replaced the plugs all 16 with e3s, all new coil plug boots and 1 coil pack because it was throwing up a code for misfire. Ran fine for a couple mths then oil light came on got code for oil pressure sensor . Changed that along with having flow master super 44 put on it. Drove a week and was raining pulled into parking lot and car just died and wouldn't restart. Got crankshaft position sensor code along with check engine light and lightning bolt and anti skid lights on. Towed it home changed cps and it will start rpms jump up and down then stalls. Won't run for more than 20 seconds. No gas pedal at all to try and keep it running. Have changed egr valve, camshaft position sensor, ignition switch, cleaned throttle body but no change. Code p3449 and p0522 check engine light and lightning bolt still on. Anybody have any ideas?
Old Jun 3, 2017 | 08:40 AM
calamity coyote's Avatar
P3449 is the MDS solenoid for cylinder 7. These solenoids going bad seem to be a common issue. I myself get random P3441 which is cylinder 6. Although it doesn't kill the engine. Just disables fuel saver mode.
The P0522 however, is low oil pressure or oil pressure sensor circuit too low. Now you already changed the sensor so it could possible be a bad oil pump. Then again, you mentioned this last mishap happened while it was raining. I've seen several reports from others who say things go crazy when it rains which means water is getting somewhere it's not suppose to. In this case, possible the PCM. From what I've read, it's suppose to be in the engine compartment mounted to the drivers fender. Based on the fact that you have so many different errors going on, I would start looking there.
Old Apr 30, 2018 | 11:03 AM
Default problem fixed
finally figured out the issue after many trial and errors. the shop who replaced my oil pressure sensor used a non mopar part so after a couple weeks it caused all kinds of electrical issues with the throttle body so it stayed in limp mode. replaced it with mopar and it's running perfect. lesson learned mopar only when replacing this part.
Old Jun 1, 2018 | 05:28 AM
Hazy518's Avatar
Default Wa
Water may be getting through the upper front cowl screen (well known problem with dodge/chrysler) and dripping directly on the TPS sensor and may run over and spill over the PCM and other electronic components close to fire wall.. if replacing tps senser do DEALERSHIP ONLY trust me’ . Auto Stores gives out universal tps..the dealership tps are not and much bigger in size.. only use dealership electrical parts for chrysler..
alaskanJK
Feb 6, 2021 09:00 AM
Sessholvlaru
May 1, 2019 11:18 PM
Chris Hertling
Jul 14, 2014 07:05 AM
DONK354
Oct 17, 2012 03:49 PM
OGHBEICA8
Jun 20, 2012 10:44 PM
