Camshaft Position Sensor Location
Old Feb 20, 2010 | 10:05 AM
rycb25's Avatar
Default Camshaft Position Sensor Location
I have a 07 Chrysler Aspen 4.7L 2wd. I took it into the dealership because it was having problems and I had a 8yr warranty on it. Well the problems were not covered under warranty. Go figure.
They said I had 2 problems one was I needed a new camshaft position sensor, and two was a new TPS. I have changed a camshaft sensor in another SUV i previously owned and it was fairly easy. Where is the location of the sensor at?
On the TPS is this easy to change? Finding the part is not easy. Or would you recommend a proffessional doing this kinda work? Thanks for any help you can give me.
Old Feb 20, 2010 | 12:35 PM
the 8 year warranty is for mechanical engine,tranny and rear end nothing electrical.
The 3-wire Throttle Position Sensor (TPS) is mounted on the throttle body and is connected to the throttle blade shaft.
The Camshaft Position Sensor (CMP) (2) is bolted to the front/top of the right cylinder head (1).
1. Raise and support vehicle.
2. Disconnect electrical connector (4) at CMP sensor.
3. Remove sensor mounting bolt (3).
4. Carefully twist sensor from cylinder head.
5. Check condition of sensor O-ring.
Old Feb 22, 2010 | 08:07 AM
rycb25's Avatar
Thanks for the help. For those who will have to change out their camshaft sensor in the future I found it easy to access it behind the passenger front tire. Its right there.
Old Dec 13, 2010 | 06:56 PM
hallpearl's Avatar
Post
Wow thank you so much. This is the best way to avoid heavy expenses this Christmas. I'll just spend it for Christmas food and not for LABOR I will also search in you tube for other guides but i guess i can follow your instructions! Cheers!
sumncguy
Apr 17, 2012 07:27 AM
jaek707
Dec 23, 2010 07:25 PM
manshack_one
Dec 13, 2010 06:59 PM
dcm1971
Oct 13, 2008 12:10 PM
jjmenard
Sep 6, 2007 05:33 PM
