Exhaust manifold heat shield fix
Old Jun 19, 2025 | 11:27 AM
Aspenmang23's Avatar
Default Exhaust manifold heat shield fix
I heard a rattling sound going over some bumps, and found the heat shield under the exhaust manifold was dangling.. looks like some of the bolts failed. So I clamped it back on with a worm gear clamp. Wish me luck!
Old Jun 23, 2025 | 08:37 AM
ggoose's Avatar
Likely the bolt holes on the heat shield rusted out. The nuts on the studs should be easy to remove. I found these washers to work well to reattach the shield.
https://www.napaonline.com/en/p/ATMN90796502
These are sized to press fit over the studs and grip the stud. I used a needle nose pliers to break off the tips at the center and slip the washer over the stud and reuse the nut.
dms1991
Jan 18, 2023 12:24 PM
sorner
Sep 20, 2021 07:02 AM
peterious
Dec 6, 2013 10:31 AM
Cliff250
Feb 11, 2012 01:58 AM
onecheck
Mar 4, 2011 08:40 PM
