Front speakers?
Old Mar 4, 2010 | 03:27 PM
kkreit01's Avatar
Default Front speakers?
8 Speaker Alpine system: does anyone know for certain what's up front? Which one of the following exists in front:
1. Component set: 6.75" Mid in door, tweeter in dash
2. 6.75" mid in door, 3.5" coax in dash
3. 6.75" coax in door, 3.5" coax in dash
It appears there's components in the rear, so I assume the same up front? Anyone replace them? At lower volumes, most sound appears to be coming from dash speakers. The mid-bass doesn't kick in until med. volume -- then it starts to sound OK.
Old Mar 5, 2010 | 04:54 PM
15951a\'s Avatar
MIDLEVEL
The midlevel speaker system features eight speakers in eight locations. One 16.5 centimeter (6.5 inch) diameter speaker is located in each front door. There is also one 16.5 centimeter (6.5 inch) diameter speaker located in each rear door. A 1.9 centimeter tweeter is mounted high in each rear door trim panel. Two tweeters (8.9 centimeter (3.5 inch)) are also located on the top portion of the instrument panel. The midlevel speaker system includes an amplifier. The total available power of the premium speaker system is 288 watts.
PREMIUM
The premium speaker system features nine speakers in nine locations. One 16.5 centimeter (6.5 inch) diameter speaker is located in each front door. There is also one 16.5 centimeter (6.5 inch) diameter speaker located in each rear door. A 1.9 centimeter tweeter is mounted high in each rear door trim panel. Two tweeters (8.9 centimeter (3.5 inch)) are also located on the top portion of the instrument panel. Included with the premium speaker package is a subwoofer located in the left rear quarter panel. The premium speaker system also includes an amplifier. The total available power of the premium speaker system is 384 watts.
Old Mar 8, 2010 | 09:39 AM
kkreit01's Avatar
Thanks much for the detailed info. 3.5" tweet! That's a bigon'.... I will probably just leave the speakers alone for now. At some point in time, I may upgrade the comp set up front.
doeboy
Sep 10, 2010 01:03 PM
Iwant2playNOW
Sep 22, 2008 06:20 PM
MantaOwner
Jan 10, 2007 11:20 AM
andypandy22a
Mar 6, 2006 10:40 PM
Dusto
Oct 3, 2005 06:38 PM
