Heat not blowing at idle
Old Oct 13, 2016 | 08:20 PM
friedj's Avatar
Default Heat not blowing at idle
Hi everyone, so its winter time here in Canada. My 2009 chrysler aspen hybrid has 160k km on it and it recently stopped blowing hot air when your idling or stopped at a red light. As soon as you start driving it blows hot again. I've replaced the thermostat and all coolant levels are fine. Any other suggestions? or if this has happened to others. I'm open to just about anything.
Old Oct 14, 2016 | 08:21 AM
warm the engine up then feel boh heater core hoses if they are both hot where yo cant hold onto them t hats good sign if one o bot are cool hen its clogged up
Old Oct 14, 2016 | 04:53 PM
grbullets's Avatar
You might want to check the water pump too. Sounds like you don't get heat until the fluid gets pushed through the heater core which could very well be partially plugged up. Check to see that pressure is being built up in the cooling system too. You may need to replace the pressure cap..
Old Oct 19, 2016 | 08:09 PM
consideringapacifica's Avatar
My 02 T&C did this last year. A quick flush on the front heater core and back to good heat at idle.
Old May 26, 2017 | 08:51 AM
Whosdis's Avatar
My mom's Aspen Hybrid has the same problem. It is the auxiliary coolant pump. This particular pump allows coolant to flow when the engine reaches NOT and shuts down.
Old Oct 31, 2017 | 09:35 PM
Syncity's Avatar
Default Did u find out the problem
Did you ever find out what the problem was. I have two Aspen Hybrids. One always blew cold air when in electric mode, the other doesn't.
Old Sep 14, 2025 | 03:05 PM
hiraeta's Avatar
Default Figured it out
it’s most definitely the auxiliary water pump. Hardest thing was finding someone who could help me find a pump as it was discontinued and no aftermarket. But after 2 brutal winter I finally found a pump that work. (Thanks to google and hrs of searching) Off a BMW. Here the part number 17127850113.
I was able to find a used one for $125 bucks and the aspen heater finally works.
it’s also located right behind the driver side front wheel well.
Old Sep 14, 2025 | 03:11 PM
hiraeta's Avatar
Default Sorry it’s the front passenger side wheel
The auxiliary pump is located behind the Front PASSENGER SIDE wheel well. Sorry correcting myself.
ss4993
Oct 29, 2019 08:22 PM
maintenance
Feb 27, 2015 02:17 PM
pmad
Sep 25, 2011 12:32 PM
davet
Dec 19, 2007 04:18 PM
Jon87transam
Aug 6, 2007 01:01 PM
