If your temp seems to "stick"...
Old Mar 31, 2012 | 07:45 PM
15951a\'s Avatar
Default If your temp seems to "stick"...
The temp showing on the EVIC in my 08 Aspen seemed to take forever to change -- sometimes 20+ minutes before it would adjust to the correct temperature, which seemed to also be affecting the automatic temperature control. I found the temp sensor online ($7), and it took five minutes to install it. Everything is working correctly again. Just FYI for anyone having this problem.
The sensor is in front of the radiator, and is easily accessed if you remove part of the black plastic fan/radiator shroud and reach down. It's held on with a simple pressure clip -- no screws.
Old Apr 4, 2012 | 11:18 AM
Triple Black 88's Avatar
Thanks for the info!
HowieF16
Oct 13, 2014 03:49 PM
memikee
Oct 9, 2014 01:15 PM
sufolino
Sep 27, 2010 12:31 PM
pghmark14
Apr 29, 2009 04:21 AM
tmay11
Mar 17, 2008 03:32 PM
