Malfunction indicator lamp not working
Old Dec 19, 2020 | 05:09 PM
Valerie Dunn's Avatar
Default Malfunction indicator lamp not working
I just bought a 2007 Aspen 5.7 hemi 4x4. I realized that the MIL isn't coming on upon start-up. I suspect that someone has disabled somehow. The reason for suspension is that it will start with the remote start then turn off. I'm hoping that a fuse has been removed or one is blown. The following is other issues that may or may not be associated with the MIL. Temperature gauge doesn't work (stays on cold, needle never moves), service park assist system, gas cap warning. Any suggestions on what fuses to check? My head hurts from researching.....
Old Dec 19, 2020 | 05:27 PM
ggoose's Avatar
You are correct with your suspicion regarding the remote start not working; if the MIL lamp is active/supposed to be on, the remote start will not work. I would go to an autoparts store and ask them to scan for diagnostic codes and get a printout of the codes. There is no single fuse for the MIL lamp so the lamp may be burned out or has been removed.
Old Dec 19, 2020 | 05:52 PM
Thank you.
Old Dec 20, 2020 | 11:56 AM
calamity coyote's Avatar
Agree. The MIL light is probably either burned out or removed. Get the codes read and report back so we can see if they are ones that others have ran across before.
As for the gas cap light, probably the ESIM. Easy fix and not expensive. Check this thread for more details. https://www.chryslerforum.com/forum/...ge-dash-30554/
Old Dec 20, 2022 | 05:06 AM
epiclarisse's Avatar
I'd fix not only the indicators. If I were you, I'd go to the service center to diagnose all the problems. But first, check the serviceability of the MIL indicator at home.
Old Dec 23, 2022 | 05:19 AM
<!--td {border: 1px solid #cccccc;}br {mso-data-placement:same-cell;}-->It doesn't look like there's a fuse there, so take it off yourself and replace the indicator light yourself. I think a small
smart led light smart led light
is suitable for this. This is suitable for many devices, and I've checked many times. If the new MIL doesn't work, go to the service center. If you have some other malfunction, their technician will see it on the error detector screen. Good luck finding problems. I hope it's just a burnt-out old light bulb.
alan8228
Jan 29, 2025 10:21 AM
Teachme
Dec 3, 2018 04:46 AM
lburnett01
Jan 8, 2018 08:50 AM
Wilfred Martinez
Jan 22, 2016 10:30 PM
alparsalan
Feb 22, 2008 10:46 AM
