Map Sensor 4,7l v8 flexfuel 2008 Engine
Old May 24, 2019 | 07:45 AM
Pierre81's Avatar
Default Map Sensor 4,7l v8 flexfuel 2008 Engine
Hello now i want to clean the map Sensor on my Aspen. The Sensor was loose and only 1 screw in it and an plastic nipple to Hold the Sensor! Most aftermarket Sensor came with 2 Screws. ????? How is it on your Aspen?
Old May 25, 2019 | 11:10 PM
themps's Avatar
pretty sure all of them have two. So it should have two. Did the screw break off in the mounting or something?
Old May 26, 2019 | 01:22 AM
Pierre81's Avatar
In one hole is only an Plastic nipple
Old May 26, 2019 | 01:34 AM
themps's Avatar
Huh, yeah I would just get the standard two slotted one. Nipple just helps keep it in place and uses the hole for the other screw. Map doesn't usually need much holding it in.
Old May 26, 2019 | 02:22 AM
Pierre81's Avatar
My Sensor was loose. Now i cleaned the map Sensor and tighten it up enough with the one screw.
Thanks 👍
Old May 26, 2019 | 12:09 PM
themps's Avatar
Thanks 👍
No problem!
RonT
Apr 2, 2015 10:21 AM
OGHBEICA8
Mar 15, 2012 07:42 PM
BadJ77
Feb 17, 2012 01:13 AM
I wonder
Jan 29, 2010 10:11 AM
beenarnd
Apr 15, 2009 09:42 PM
