Need help with non-working brake lights
Old May 14, 2012 | 09:06 PM
Cliff's Avatar
Default Need help with non-working brake lights
My 2008 Aspen as mysteriously deleloped a issue with the right and left brake lights not working. The third brake light on the hatch does work so that should rule out the brake switch on the pedal right?
The turn signals and park lamps also work fine. I believe that I've checked all related fuses and all seem fine. Checked the bulbs and they look good also. Called the dealer and they said that it could possibly be that the actuall bulb sockets have gone bad. What's the chance that both sides and the same socket on both sides have gone bad at the same time. I'm a former line worker from the St Louis North Plant and I'm still out of work going to school full time. I can't afford to have the dealer figure this out and there telling me to buy $100 worth of parts that probably seem to me won't fix the problem.
Any ideas guys? Sure could use some direction here!
Cliff
Old May 14, 2012 | 10:22 PM
TNtech's Avatar
It CAN still be the brake switch. The signal to the modules and the hardwired feed to the center are 2 separate outputs. The only way you can know if the signal is getting out is to read the data in the FCM, ABS, etc.
Anyway, the FCM controls the lower brake lamps, but the power passes through the IPM and then through the Junction Block before it gets back there. A bit of meter work involved, so make sure and check those sockets and bulbs first. I have seen both bulbs popped quite a few times on different cars. Don't let it bite you.
Old Jun 28, 2012 | 09:06 AM
dpitchers's Avatar
I am having the same issue with a 2007 Aspen. Right and left brake lights are out. Upper brake light still works. Replaced both bulbs and they are still out. Dealer service department stated if replacing the lights did not fix the issue it could then be the light switch. Their suggestion was to "wiggle" the switch and see if the brake lights begin to work. If not then the switch will need to be replaced.
Old Jun 28, 2012 | 10:28 AM
TNtech's Avatar
No technician with half a brain would ever say that. Multimeters and scan tools exist for a reason. If they really said that, take your car somewhere else.
Old Jun 30, 2012 | 03:24 PM
15951a\'s Avatar
I'm pretty sure the tech was trying to help him out by giving him a suggestion to troubleshoot it at home rather than to pay $100 for diagnostics.
Old Feb 20, 2025 | 10:12 AM
tmills's Avatar
I am working through the same thing with my 08. I have changed the brake switch, fuses, and relays. Anything that said stop lamp or ABS. The strange part is when I start the car and then push the brake pedal the brake lights come on for a second and then go out. This is consistent. Every time I turn the ignition on with out starting and push the brake they flash and go out. Start he car push the brake they flash and go out.
Any ideas?
4everrunning
Jun 4, 2019 11:30 AM
johnseattle
Jun 20, 2008 07:47 PM
calpacifica
Aug 26, 2007 04:40 PM
