Red circle security light on lit and nothing works
Old May 6, 2022 | 11:49 AM
Lembi33071's Avatar
Default Red circle security light on lit and nothing works
Hello,
I have a 2008 Aspen. When I was trying to go to work yesterday morning after turning my key to the start position and after all the dashboard lights went on like everyday as usual, when I turned the key to the end to start the vehicle a "click" noise happened and all the lights went off... after that nothing works... key fobs, lights, nothing... the vehicle is dead... with the exception of a circle red lit light on the dashboard.... I though it was the battery so I replaced it and nothing happened... I tried to jump start it and nothing... I checked all fuses all fuses are good.. I tried my second key and nothing... any thoughts???
Thanks..
Old May 6, 2022 | 12:30 PM
skim module issue a shop will need to take care of this for you
Old May 11, 2022 | 08:36 AM
Lembi33071's Avatar
When the skim module is bad, do you still get power in other areas of the vehicle?
Old May 11, 2022 | 08:21 PM
calamity coyote's Avatar
From what I'm reading online about the Skim Module, yes. You would still see power to other devices in the vehicle. It just won't start. Dash of course goes dead when you try to crank as it usually does even when working properly. The Skim Module is part of the security feature. It reads the codes from the Sentry keys to allow it to start. This Skim Module then sends a message to the PCM to allow it to start. If the Skim Module is not reading the codes from the keys, the PCM will not allow vehicle to start. I am also seeing multiple post about having the Skim Module disconnected so you no longer have the Sentry system, but you then have to send you PCM to someone to have it cleared of the current Skim Module. Looks to be around $100. Google Chrysler Skim Module and you will see all kinds of info on this. Only other option, like Chrysler Tech said, take it to a dealer to get it fixed.
Personally, I would first look to see if the Skim Module has become disconnected or loose. It is located under the steering column by where you insert the key. Just have to remove the cover to see it. Probably a long shot, but if it did somehow come loose, you will kick yourself if it was that simple and you have to fork out 1 hr tech fee for something you could of just plugged back in. Just don't mess with any plugs or wires that are yellow. These are for air bag system.
Old May 12, 2022 | 08:33 AM
Lembi33071's Avatar
Thanks for the answer... I have no power in the entire vehicle, so I don't think skim module is my problem, I wonder if there is a main fuse somewhere in the vehicle that I can check or what else this issue could be!! I appreciate you help.
Old May 13, 2022 | 08:19 PM
Lembi33071's Avatar
Update: I brought a mobile mechanic, he turned the key to the on position, connected the negative terminal and then the positive terminal and then went inside and turned it on........ I was shocked.....
Old May 14, 2022 | 08:15 PM
Sounds like it may have been an actual issue with the battery/cabling then. Perhaps bad cables. I've seen that happen before. They get corrosion built up inside the cable which you can't see because the wire sheathing hides it.
Old May 15, 2022 | 02:39 PM
Lembi33071's Avatar
Yes, that's a high probability!!! next time this happens I will run tests with multimeter to catch where the issue is coming from. Any suggestions?
Old May 15, 2022 | 02:47 PM
He reset the skim module it will likely come back.
Tony Gunk
Jan 17, 2022 05:22 PM
morganfam77
Jun 21, 2011 05:32 PM
wmac500
Aug 3, 2010 09:07 AM
Tucson Pacificar
Jun 10, 2010 12:32 PM
lobsteprost
Nov 11, 2007 07:37 PM
