Stuck wheel hub bearing
Old May 21, 2016 | 09:05 PM
purplepuller's Avatar
Default Stuck wheel hub bearing
Doing complete Brake job on Aspen Left front dust shield is rusted really bad caused by caliper stuck two years ago( got really hot replaced caliper with reman caliper ,rotor and pads are shot after 20,000 miles installing new brake hose also) . So have to pull bearing to replace dust shield but cannot get bearing out Trying to save it if possible. Any tricks out there?
Old May 23, 2016 | 12:02 AM
a slide hammer will get it off
Old May 23, 2016 | 03:54 PM
Got the bearing out, but ended up taking knuckle off vehicle and using longer bolts to hit on with small sledge from the back side of knuckle. Well after cleaning up aluminum corrosion on the knuckle the bearing is too loose in knuckle. So have new OEM knuckle,bearing and dust shield ordered. The heat from the stuck caliper really did a number on the Knuckle.
Old May 31, 2016 | 08:40 PM
peter123wallace's Avatar
Tell us how it goes when the parts arrive.
Old Jun 1, 2016 | 05:24 PM
Got it all together over the weekend. New pieces go together nice! Put the Powerstop brakes on it.
Bojib
Apr 11, 2015 11:28 AM
pob
23
May 30, 2014 04:47 PM
travelmad
Aug 28, 2013 04:36 PM
Vasiliki-Greece
Jun 12, 2009 06:34 AM
gareth111278
Nov 22, 2008 06:39 AM
