Towing a 28ft boat
Old Jun 10, 2009 | 01:09 PM
daviddooley's Avatar
Default Towing a 28ft boat
I have a 2007 Aspen with the 5.7L Hemi. I bought it used and it did not come with the trailer tow package. If I get a hitch installed, do you think I'll have any problems pulling a 6,000lb 28ft speed boat? The trailer is probably another 1,200lbs. Just wonder other thoughts. Thanks!
Old Jun 10, 2009 | 07:20 PM
Check the owners manual, available at chrysler.com. If you are planning on freeway speeds and long distances, be conservative in loading the car. If you are pulling for a few miles at low speeds, you can probably get away with heavier loads. Personally, I think 7200 lbs on an Aspen is pushing your luck.
Old Jun 10, 2009 | 10:27 PM
Al B's Avatar
An Aspen with the 5.7 Hemi, 3:93 Rear End Gear Ratio, and tow package, is good for 8900lbs Towing. Personally, I wouldn't do that on a daily basis, my nuckles wouldn't have any color left in them. BUT, I will say the anti-roll midigation will handle that kind of weight quite well.
daviddooley, I would be sure to add ALL of the components for the tow package. Transmission/steering cooler, wiring, hitch etc. 7200lbs is alot for the tranny, even on short trips, the engine will have no problems what so ever. I can only guess to say that the vehicle is prewired for the package, and that adding a brake controller with the OEM harness, would be a breeze.
Hope this helps.
Old May 26, 2021 | 05:10 PM
Simondalle5's Avatar
Man 6000lbs is way too much you should look at Boat shipping Expert to done similar kind of work. Trailer hitches are often broken into classes that range from the lightweight Class I trailer hitch, to heavy Class V hitches. Outside of the standard hitch class are gooseneck and fifth wheel connections that have their own weight limits to take into consideration.
Old Aug 27, 2021 | 10:47 PM
bradleybbb's Avatar
Default Poor Aspen
Looks like we're gonna lose another one from pure overwork and exhaustion. 28 ft boat !!
goodbye little one RIP
Scott Ulrich
Aug 22, 2022 08:32 AM
Dbuck2013
Oct 22, 2015 04:44 PM
Nathan Lawson
Oct 19, 2015 12:27 PM
mrk
Oct 3, 2013 03:24 PM
95Jersey
Oct 6, 2008 08:43 PM
