Trailer running lights
Old Dec 23, 2010 | 06:47 PM
conversion02's Avatar
Default Trailer running lights
My trailer running lights don't work. Flashers, brakes, and turn signals work, but the running lights are out. I checked the output to make sure nothing was wrong with the trailer and there's no output from the vehicle at the trailer harness.
Sounds like a fuse, but why (and WHERE?) would Chrysler wire up running lights on the tow package independently from the others (flashers and brakes)? I saw a fuse in the box for the tow lights, but that was it. Is there a separate fuse (10A?) for the trailer running lights???
Thanks!
Old Dec 23, 2010 | 08:59 PM
nm - i found it the 10A fuse. works like a charm now.
Old Aug 13, 2019 | 09:22 PM
Shane Calonge's Avatar
Default Where was it
Where was it located under the hood or steering wheel
Old Dec 31, 2023 | 04:54 PM
mpalmer772's Avatar
I'm having thus exact same problem. I switched out the relays and a 20A fuse for tgthe tow package but still no running lights.
It would be nice to know where this 10A fuse is 😁
Old Dec 31, 2023 | 08:28 PM
calamity coyote's Avatar
Multiple fuses under the hood with two boxes.
Power Distribution Center is the box closest to windshield.
Cavity 23 - 20 Amp Yellow - Trailer Tow
Integrated Power Module, second box from windshield.
Cavity 5 - Relay - Lt Trailer-Tow Stop/Turn Relay
Cavity 6 - Relay - Rt Trailer-Tow Stop/Turn Relay
Cavity 9 - 10 Amp Red - Trailer Tow Park Lamps
So looks like you are looking for a red 10 amp fuse in the second box under the hood. It will be the one closes to front of vehicle on the right when you raise the hood.
Old Jan 3, 2024 | 04:33 PM
mpalmer772's Avatar
It looks like i missed the red 10A fuse for trailer park lights. This has to be the problem. I'll check the current at the 4-pin after i switch it out. It was very nerve racking to be pulling a trailer as the sun went down. At least my brake and turn signals work.
I replaced the two relays with what was already there (pic attached). I used the numbers on top to find a replacement.
silentdub
Aug 11, 2017 12:21 AM
billdc
Apr 14, 2015 02:45 PM
Tommy Harrell
Nov 8, 2013 07:19 AM
georgeo
May 15, 2008 09:04 PM
timtrekker
Mar 10, 2008 10:06 PM
