Chrysler Crossfire & Crossfire SRT-6 The base model offers a coupe, convertible, or roadster, but regardless of the model chosen this luxury sports car offers pure driving enjoyment and for those who want a few extra ponies under the hood the supercharged model offers the driver 330 hp
2005 Crossfire issue
Old Jun 4, 2022 | 07:02 AM
tromjf60's Avatar
Default 2005 Crossfire issue
Once in a while, I get a PO171 code. Car runs fine, so I put it out. Replaced Map Air, and two Bosch upstream 02 sensors. But it still comes on once in a while. Dealer says new sensors aren't OEM so they don't see the voltages changing the way they should. I can't find any new OEM 02 sensors, and I wonder if that is my actual problem. I could use some help. Thanks
Old Jun 20, 2022 | 12:59 PM
Bosch sensors don't seem to work well with Chrysler products. One would think that could be your problem except that the Crossfire was actually a Mercedes product. Might want to get some sensors from a Mercedes dealership and try those. The other consideration is that the way O2 sensors work is that the computer compares the readings from the upstream sensor to the reading from the downstream sensor to determine how well the catalytic converter is working. As the sensors age with use, the ratio should remain the same. If you change only the upstream sensors, the computer is trying to compare the reading from a new upstream sensor to the reading from an old downstream sensor and it's getting confused. Changing all sensors, up- and downstream at the same time might solve the problem.
Old Mar 27, 2023 | 06:58 PM
Dpweaver's Avatar
I had the same issue with my car after closer inspection I found a crack in the top of the catalytic converter on the driver side, right in the seam , removed the driver side, exhaust pipe, and re-welded the seam with stainless steel rod. No more problem. All is well.
UberPacifica2005
Feb 6, 2021 10:29 AM
Wolfgang R
Dec 4, 2019 02:25 PM
scooby
Sep 30, 2012 10:50 PM
xfire04
Nov 13, 2007 03:52 PM
whiteblitz23
Nov 12, 2007 07:22 PM
