´08 Pacifica vibration only at +59mph
Old Aug 10, 2015 | 10:53 PM
omni75's Avatar
Default ´08 Pacifica vibration only at +59mph
Hello everyone.
I have a 2008 Pacifica 6cyl, automatic. At speeds over 59mph, there is a vibration felt in the floor, driver and passenger seats, it is strong enough that the passenger can feel it (nothing in steering wheel). After I had the right rear wheel bearing replaced, it started this vibration felt in the driver and passenger seats. The bearing was corroded in and had to be soaked in PB Blaster and beaten out with a sledgehammer.
The mechanic who drove the car to diagnose the problem didnt have any idea what was wrong. They put it on a lift and said everything looked fine. It looks like they want to throw parts at it until its fixed at $80/hr plus parts.
Any thoughts/ comments would be greatly appreciated.
Old Aug 12, 2015 | 02:52 PM
ChryslerCares's Avatar
Hi omni75,
I couldn't find any TSBs that would be applicable to this specific concern. Is the vehicle at an FCA dealership that I could contact to try to assist from a corporate standpoint?
Old Aug 12, 2015 | 10:11 PM
cirrus98's Avatar
Raise the rear of the vehicule and turn the wheels by hand, give them a good spin. If the bearings are fine, you should hear any grinding and rubbing what so ever. Also, what did you do/not do for a bearing to become corroded. I'm thinking that you're corrosion is alot worse than you think it is, and should proceed with a test to check bearing on both sides.
Old Aug 18, 2015 | 10:13 PM
First thing to suspect for a vibration at speed is wheel balance. It's cheap to check and repair. Rule that out and go from there.
tcook726
Jul 5, 2014 01:45 PM
KingJB
Jan 29, 2014 05:13 PM
Merglers
Jan 9, 2011 07:48 PM
Hawwk11
Aug 21, 2007 12:47 AM
cplcarlman
Jul 26, 2007 04:45 PM
