04 2wd Pacifica Major Blower motor/resistor issues
Old Jan 22, 2014 | 10:13 PM
Christopher's Avatar
Default 04 2wd Pacifica Major Blower motor/resistor issues
My problems started 2 years ago. My wife's 04 Pacifica's air stopped working. Quick web search said replace the blower motor resistor behind the glove box. $112.00 later her air works great. A year later it goes out again. Thank God for lifetime Warranties! Replaced and good to go. 3 months later it goes out again. Since then We have replaced it three more times. Now the air is stuck on high whether the controls are on or not. I was told by a Mechanic that it sounds to him like the actual Blower motor is going out. Possibly the bearings are wearing out and making the motor draw more current which is burning out the Resistors. The air does seem a little weak. Has anyone heard of anything like this and could the motor actually be burning up the resistors?
Old Jan 22, 2014 | 10:28 PM
consideringapacifica's Avatar
Wink
My daughter's 01 Caravan burnt a resister due to a plugged cabin air filter. It had never been changed until the resister failed at 90k miles.
Old Jan 22, 2014 | 10:43 PM
We change her's every other oil change. I found out about the filter when she burnt up the first resistor.
Old Jan 22, 2014 | 11:05 PM
I have seen bad blower motors take out resisters on Ford Rangers at work.
Old Jan 23, 2014 | 07:40 PM
they will on Chrysler a motor is a motor
Old Apr 26, 2014 | 06:29 PM
levispur's Avatar
Default 2006 Pacifica blower moter not working
I have no air coming out of front or rear vents.....please help! I swapped the fuse but no luck.
Old Apr 27, 2014 | 12:02 AM
cirrus98's Avatar
I had the same problem. The blower motor is DONE. You will be able to get at it from under the glove box. 1 screw will require to take out the glove box but other than that, pretty straight foward.
Here's a link:
http://www.helletech.com/randomdownl...lowermotor.pdf
Vanman
15
Jul 17, 2009 06:17 PM
netdealz
Nov 26, 2008 06:09 PM
mrotis
Jan 14, 2008 01:27 PM
bmfay
Apr 9, 2007 08:37 PM
bmfay
Apr 2, 2007 09:49 PM
