04-pac head light question
I have a 04 Pacifica that I've had to replace the pass side head light 3 times and this morning the driver side went out. This will be the 3rd time of this side now. Each time I take it to the dealership to replace since I don't have the tool to do it myself (I'm told it takes a special tool specifically for the pac). I've asked the dealership to specific look at why this is so often and each time told the headlight simply burned out. This seems like too often. Has anyone else expreienced the same or has heard of this happening that can offer a suggestion? Thanks.
I changed my driver side before, the only thing you have to do is take out the battery and flip over the fuse box (its meant that way you will see where teh springs are) and remove the black rubber protection. Then reach in twist counter clockwise till it can be pulled out. replace the bulb and put everything back.
I have a 04 Pacifica that I've had to replace the pass side head light 3 times and this morning the driver side went out. This will be the 3rd time of this side now. Each time I take it to the dealership to replace since I don't have the tool to do it myself (I'm told it takes a special tool specifically for the pac). I've asked the dealership to specific look at why this is so often and each time told the headlight simply burned out. This seems like too often. Has anyone else experienced the same or has heard of this happening that can offer a suggestion? Thanks.
Let me know if you have any questions.....
cathycraig1970
Mar 16, 2012 06:52 PM
bwinterstine
Nov 1, 2011 12:31 AM
Diggitydigs
Sep 15, 2011 09:06 AM
aschabel
Aug 28, 2010 12:18 PM
