04-pac head light question
Old Apr 14, 2009 | 08:59 AM
pacdriver's Avatar
Default 04-pac head light question
I have a 04 Pacifica that I've had to replace the pass side head light 3 times and this morning the driver side went out. This will be the 3rd time of this side now. Each time I take it to the dealership to replace since I don't have the tool to do it myself (I'm told it takes a special tool specifically for the pac). I've asked the dealership to specific look at why this is so often and each time told the headlight simply burned out. This seems like too often. Has anyone else expreienced the same or has heard of this happening that can offer a suggestion? Thanks.
Old Apr 14, 2009 | 12:35 PM
ladisgsx's Avatar
I changed my driver side before, the only thing you have to do is take out the battery and flip over the fuse box (its meant that way you will see where teh springs are) and remove the black rubber protection. Then reach in twist counter clockwise till it can be pulled out. replace the bulb and put everything back.
Old Apr 14, 2009 | 04:10 PM
kevex's Avatar
I'm pretty sure that you can take out the headlight with 2 screws and change the bulb that way, it'll be easier than taking the battery out. On my 05 anyway
Kevin
Old Apr 27, 2009 | 07:28 AM
psimon's Avatar
Talking
Originally Posted by pacdriver
I have a 04 Pacifica that I've had to replace the pass side head light 3 times and this morning the driver side went out. This will be the 3rd time of this side now. Each time I take it to the dealership to replace since I don't have the tool to do it myself (I'm told it takes a special tool specifically for the pac). I've asked the dealership to specific look at why this is so often and each time told the headlight simply burned out. This seems like too often. Has anyone else experienced the same or has heard of this happening that can offer a suggestion? Thanks.
Replacing headlights on the Pacifica is REALLY EASY and all it requires is a screwdriver or an appropriate sized box wrench. I can say this with assurance because I have done this numerous times. The reason I do this often is that I am running the brighter than normal bulbs, which yield more light but don't last anywhere near as long. Consequently, At least once a year, if not more I am changing a bulb. You only need to take out the 2 screws that are on top of the headlight and slide the assembly out the front. It does clip in and must be unclipped requiring a little bit of pressure, but that's it! NO SPECIAL TOOLS REQUIRED AT ALL!
Let me know if you have any questions.....
Old Apr 27, 2009 | 07:39 AM
PacificaBus's Avatar
Note, from my experience it can be a bit tricky. You will need to finagle it out and in but it's not that difficult.
cathycraig1970
Mar 16, 2012 06:52 PM
bwinterstine
Nov 1, 2011 12:31 AM
Diggitydigs
Sep 15, 2011 09:06 AM
thatendswell
Jul 29, 2011 09:24 PM
aschabel
Aug 28, 2010 12:18 PM
