'04 Pacifica: Blend door vs. Mode door actuator...
Are they one in the same?
Basically, my air only comes out of my main vents, no floor, no defrost. My thought is I need a mode door actuator, and the light is out on my A/C panel where the mode switch is. Other lights are working. I assume that's my A/C panel's way of telling me.
When I search for mode door actuator, descriptions say blend door. I thought blend door determined how much hot/cold air comes through. Temperature works just fine, BTW.
Is this tough to repair myself? I've had to fix my resistor pack in the past, and I've repaired both front door window regulators.
Even the description of this item is ambiguous. It says blend door, but it also says Mode Defrost Door Motor.
Blend Door Actuator 4885465AA Mopar Mode Defrost Door Motor Servo | eBay
Jwrbloom
Oct 15, 2013 03:46 PM
