'04 Pacifica: Blend door vs. Mode door actuator...
Old Nov 27, 2012 | 07:58 AM
Jwrbloom's Avatar
Default '04 Pacifica: Blend door vs. Mode door actuator...
Are they one in the same?
Basically, my air only comes out of my main vents, no floor, no defrost. My thought is I need a mode door actuator, and the light is out on my A/C panel where the mode switch is. Other lights are working. I assume that's my A/C panel's way of telling me.
When I search for mode door actuator, descriptions say blend door. I thought blend door determined how much hot/cold air comes through. Temperature works just fine, BTW.
Is this tough to repair myself? I've had to fix my resistor pack in the past, and I've repaired both front door window regulators.
Old Nov 27, 2012 | 08:23 AM
Jwrbloom's Avatar
Even the description of this item is ambiguous. It says blend door, but it also says Mode Defrost Door Motor.
Blend Door Actuator 4885465AA Mopar Mode Defrost Door Motor Servo | eBay
Old Nov 27, 2012 | 09:55 AM
Mode door is Number 2 remove pass side lower duct and then u can see them all right there
Attached Thumbnails '04 Pacifica:  Blend door vs. Mode door actuator...-80adab8d.jpg
Old Nov 27, 2012 | 10:47 AM
Jwrbloom's Avatar
Is what I linked the part I need?
Old Nov 27, 2012 | 06:31 PM
i guess so I dont have access to part numbers to tell u
Old Nov 28, 2012 | 02:16 AM
ConradMccar's Avatar
Check all wiring for the cam sensor.
Raider
Sep 21, 2021 10:42 PM
kentchris
Aug 2, 2016 12:26 PM
Jwrbloom
Oct 15, 2013 03:46 PM
EdOv
Jan 8, 2012 12:25 AM
dbmonty
Dec 28, 2010 09:30 PM
