04 pacifica heat
Old Mar 5, 2009 | 01:48 PM
speedy_31's Avatar
Default 04 pacifica heat
im having a problem with changing from floor to vent & vice versa. i can change it to the floor & it blows out the defroster & very little on the floor. is there a way to reprogram the unit. i have the digital unit.
Old Mar 5, 2009 | 09:33 PM
dusty-schaffner's Avatar
i dont exactly have much knowledge on digital climate control but if the valves still operate on vacuum then check the vacuum lines
Old Mar 6, 2009 | 07:55 AM
goldsmi's Avatar
The blend air actuators are DC servo motors, not vacuum motors.
If airflow is an issue, check/replace the cabin air filter.
The two blend air actuators (one for the front, one for the rear) are indentical components. If airflow is OK, and the problem is airflow direction you could swap the actuators. If the problem moves with the actuator, you've found the problem.
reyesraiders1
Nov 11, 2010 09:39 PM
hvychvyman
Jan 17, 2009 02:49 PM
RobW
Nov 14, 2008 10:54 PM
davet
Dec 19, 2007 04:18 PM
bluepacifica
Apr 27, 2007 04:41 PM
