04 pacifica misfiring p301,p302
Old Apr 1, 2010 | 07:45 PM
epac's Avatar
Default 04 pacifica misfiring p301,p302
2004 pacifica continiously misfiring diagnostic shows cylinder 2 misfiring I replaced the spark plugs didnt work replaced the coil didnt work and finally replaced injector but still cylinder 2 misfiring anybody please tell me what else to try diagnostic shows 301 and 302 and I beleive cylinder 2 is the middle one from the front row under the intake
Old Apr 1, 2010 | 10:54 PM
Virglijus's Avatar
All possible causes:
INTERMITTENT MISFIRE
VISUAL AND PHYSICAL INSPECTION
IGNITION WIRE
ASD RELAY OUPUT CIRCUIT (COIL)
ENGINE MECHANICAL PROBLEM
IGNITION COIL
COIL CONTROL CIRCUIT
SPARK PLUG
CHECKING FUEL PRESSURE
FUEL PUMP INLET STRAINER PLUGGED
RESTRICTED FUEL SUPPLY LINE
FUEL PUMP MODULE
CHECKING FUEL LEAK DOWN
FUEL INJECTOR OPERATION
ASD RELAY OUTPUT CIRCUIT (INJECTOR)
FUEL INJECTOR
INJECTOR CONTROL CIRCUIT
PCM (IGNITION SYSTEM)
Old Apr 2, 2010 | 01:27 AM
mrfixit454's Avatar
isn't 301 and 302 a #1 and #2 misfire?
Old Apr 2, 2010 | 02:59 AM
Virglijus's Avatar
Yes, it is. The cylinders are numbered from front to rear, with the right bank odd numbered, and the left bank even numbered.
RCSnyder
May 24, 2014 09:12 PM
ronypal
Mar 29, 2012 06:20 PM
LemonSebring98
Jul 4, 2011 11:15 AM
ddalbyr
May 12, 2011 09:19 AM
ChryslerNamedTrixie
Sep 20, 2005 04:57 AM
