05 Chrysler Pacifica Remote Car Starter
Old Jan 27, 2011 | 03:47 PM
Element's Avatar
Default 05 Chrysler Pacifica Remote Car Starter
Hi I just bought a Pacifica from a dealership and the remote car starter attempts to start car 3 times and it just doesn't turn over. This is the factory Mopar Remote car starter. If you know how to fix this please let me know. Thankyou.
Old Jan 27, 2011 | 06:01 PM
busboy4's Avatar
Is the horn honking at all during the process? If so, how many times? I would upload the installation/troubleshooting file but it is too big. Meanwhile, just for grins see if it is in "service mode". To get it out:
2. Exiting Service mode.
A. Turn ignition on with the key.
B. Press the start button on the remote transmitter 3 times. 2 seconds later,
the horn will chirp and the lights will flash 1 time, indicating the system
has exited Service mode.
Old Jan 27, 2011 | 10:05 PM
Element's Avatar
the horn does not honk but the last time I tried it the alarm went off right away and would not turn off until I went in the car and turned the on.
Old Jan 27, 2011 | 10:23 PM
Djinn-n-Tonic's Avatar
Do the parking lamps Flash?????
Make sure the "HOOD SWITCH" has not fallen off. This makes it so it cant be started remotely with the hood open
Old Jan 28, 2011 | 01:26 AM
Element's Avatar
Yes they do
Old Jan 28, 2011 | 08:38 AM
busboy4's Avatar
Well I hope you can get if figured out. I have a remote start on another vehicle and love it. I'll attach the "troubleshooting" page from the directions I downloaded. You'll see why I asked about the horn. By the way, the directions indicate that for normal start you should push the start button twice (2X). Remote shutdown is push and hold start button 2+ seconds.
File Type: pdf
Old Feb 11, 2011 | 07:41 AM
teamfatmouse's Avatar
It sounds like the link between the remote start and the anti theft, when the remote start engages it triggers the security which in turn triggers the starter lockout. if this is an after market remote starter more than likely you can add or have repaired the pack that shuts down the factory security, to use the remote start. if it is the mopar unit, they are not supposed to be used with vehicles with the EVS systems installed.
Grenadiers
Aug 24, 2020 11:13 AM
monchito_yeyeye
Oct 18, 2012 12:57 PM
Bib
Jan 27, 2012 01:43 PM
ejbar911
Nov 9, 2009 03:20 PM
ejbar911
Oct 14, 2008 07:07 AM
