06 Pacifica 1500-2000RPM loop
Old Nov 23, 2009 | 02:49 PM
Chrysler group's Avatar
Default 06 Pacifica 1500-2000RPM loop
I have a 06 pacifica touring AWD and I notice when the engine is not warm when I push the gas pedal the car do not response for a couples of seconds, in fact it when it reach 2000RPM it come back to 1500RPM ( do not reponse to gas pedal). I changed EGR valve, spark plugs, TPS sensor and do the fuel injector service; the problem is still there. The most wierd fact is if the vehicle reach the speed to automatic door look act, then the it have a good response. I mean the problem always happen before automatic door lock acts. Does anybody have any idea about this???? Thanks!
Old Feb 11, 2010 | 08:51 AM
Default Pcm
Problem was the PCM. I just replace the PCM with a rebuilt one and that solve the problem.
Old Feb 11, 2010 | 01:45 PM
mrfixit454's Avatar
How did you determine it was the PCM?
Old Feb 12, 2010 | 06:47 AM
It was hard work. First, scan the pcm once and obtain: Bad egr valve (solve), then scan PCM: (wrong sparkplug) and was the oem spark plug, I changed them. Scan PCM: (TPS slow response) I changed TPS. Scan PCM: (O2 sensor heater circuit) I changed O2 sensor (both of them). Scan PCM: (Air intake circuit one open) checked and circuit was good. At this moment the car still has the problem. Some times passeger Airbag disconneted light comes on. The funny part was if the automatic door look act the the car didn't fail. I wasn't sure the problem was the PCM, but I took the risk and that solved the problem.
Old Feb 12, 2010 | 10:57 AM
mrfixit454's Avatar
Ok, thanks.. so were all those components really OK. So you still have some problems or is it all OK now?
Old Feb 13, 2010 | 07:26 AM
The vehicle is working just like new! Everything is fine!
Old Feb 14, 2010 | 08:46 PM
Cracker's Avatar
Wouldn't a reflash have the same outcome or was it determined that there was a hardware failure within the PCM?
Old Feb 15, 2010 | 09:06 AM
At this point I can't tell you if a reflash solve the problem, I didn't try to reflash the original PCM because the dealer ask me for more money to reflash my old PCm that the money I paid for the rebuild one. it came programed with the mileage and VIN of my pacifica for 150$ (ebay seller), a kind of plug and play!
Old Feb 15, 2010 | 03:58 PM
Cracker's Avatar
Not a bad deal at all! I wish Stealerships would treat their customers better, especially when having an issue with THEIR product!
Wheelman_60
Jul 26, 2015 02:30 PM
dazzzzbo.uk
11
Sep 9, 2014 05:26 PM
Ephata
18
Jun 4, 2014 02:14 PM
DaveSiever
Jun 3, 2014 03:23 PM
hoef
Mar 23, 2011 11:17 AM
