06 Pacifica ABS light on
Old Sep 28, 2010 | 08:09 PM
Brooks72's Avatar
Default 06 Pacifica ABS light on
Is there any connection to the ABS light being on and needing rear brakes? The sensor on the pad just started touching. Can I replace the rear brakes myself or is the below statement I found on the web true? Thanks in advance!
you cannot do it yourself because the ABS will sense that brakes are being changed and will cause the immobilisor to cut in and only the dealers can release the immobilisor ,so its a dealer only job .
Old Sep 29, 2010 | 09:04 AM
there is no such sensor to detect the brake pads being worn on a Chrysler
the abs sensor is used on a metal tone wheel on the bearing housing not brake pads.
get the abs light scanned and see what the code is.
jimmy154
Dec 14, 2019 09:45 PM
sxdc58
Mar 28, 2018 10:22 AM
pearly28
Oct 9, 2010 12:18 PM
notVERYpleased
Jul 24, 2007 10:19 AM
chrysler34
Mar 18, 2007 03:33 PM
