06 Pacifica Transmission Issue
Old Aug 7, 2019 | 07:30 AM
tech62571's Avatar
Default 06 Pacifica Transmission Issue
while driving at about 50 or over, when I accelerate the cars starts to shudder unless I accelerate very slowly.
also today when I pulled off the highway after doing 75, it was stuck in what appeared to be 2nd gear.
put it in auto stick and all the lights were lit and the gear read 8
I turned off the car and restarted it. then it shifted normal from 1st
Old Aug 29, 2019 | 08:29 PM
Digger02's Avatar
Take this for what its worth - I had similar problems with shuddering at 55 mph and drove my 2008 in autostick for months to try to avoid it. One day while trying to accelerate quickly at a merge point, I got a cylinder misfire and lit up all check engine lights, flashing on and off. I changed all the plugs at 160K miles (probably 1st time they were ever changed) and the gaps were gigantic due to erosion of the top wire. When I put new double-platinums in, all my hard clunky shifts and shuddering problems went away. Its a cheap fix worth trying.
Old Sep 3, 2019 | 09:12 AM
tech62571's Avatar
I pulled the codes ..
P0700
P0734
Old Sep 4, 2019 | 10:08 PM
That Jeep Guy's Avatar
The research I just did said the problem is usually the Input Speed Sensor.
Buy a genuine Mopar sensor, because Chrysler products do not like aftermarket sensors.
It should be on the front side of the transmission, closest to the engine.
I believe one post said they used a 1" socket to change it.
I hope that helps!
Old Sep 17, 2019 | 08:37 PM
tech62571's Avatar
thanks for the info.. I ordered it.. only $25.. def worth a try
Old Sep 27, 2019 | 02:51 PM
tech62571's Avatar
I changed the part and the studder seems to be gone.
but it still seems to lock into 2nd gear when i get off the freeway
Old Sep 27, 2019 | 04:24 PM
It sounds like it may have another issue.
See if it's throwing another code.
Glad the shudder is gone, btw.
Cameron Texter
Jul 13, 2017 09:43 AM
chaimp
9
Jul 18, 2015 04:19 PM
littlemonster
Aug 20, 2011 11:30 AM
Ran
Apr 11, 2008 06:53 AM
tree8588
Feb 22, 2007 10:57 PM
