2004 Chrysler Pacifica Will Crank but Won't Start. I need help!
Old Jun 10, 2020 | 08:06 AM
Mike Sandlin's Avatar
Default 2004 Chrysler Pacifica Will Crank but Won't Start. I need help!
I have a 2004 Chrysler Pacifica that has been sitting for awhile. I've changed the spark plugs and the coil packs. I've installed a brand new battery. I've noticed that the shifter won't engage in park, or at least the indicator on the dash says it won't go into park. I've tried starting it in neutral and it will turn over but will not start. I visually checked some of the fuses under the hood, but they seem fine. Please help! I've poured about 10 gallons of fresh gas in it also.
Old Aug 30, 2020 | 06:32 PM
08Pacifica4.0shadetree's Avatar
Sounds like it’s getting no fuel. I would take the air intake plentiful off, remove the clips that hold the hold fuel rail to the injectors and it squirt at u a little with just some movement not completely removing it. If not u need fuel pumps. There is 2 under middle row seats I can show u how to replace them if need be. About 150-200 each.
Joe Scalesse Jr.
Nov 27, 2019 08:36 AM
darrenburry
May 10, 2017 09:24 PM
stainless steel
Feb 23, 2012 09:45 PM
winters1219
Nov 11, 2010 08:07 PM
alaskanJK
Feb 20, 2009 04:11 AM
