2004 pacifica
Old Feb 27, 2015 | 11:35 AM
waterguy's Avatar
Default 2004 pacifica
Does anyone notice your Pacifica having a weird body roll when going over bumps and dips in the road?
Old Aug 28, 2020 | 08:04 PM
fredonia5961's Avatar
look under the front and see if there are any rust pockets any where on the engine cradle.
Also look to see if the cradle bolts are tight ( loose ones leave scratches. ). Look at the back too; better safe then sorry and all that.
Could be nothin but worn sway grommets but if either of those other two are found it could be scary.
A couple other things I'm not bringing up because those reason make noises.
Just sayin these rigs don't have body roll.
Old Aug 30, 2020 | 07:43 AM
djetelina's Avatar
My Pac had a weird body roll due to totally worn out shocks and struts.
Replaced the rear shocks, pretty much easy peasy using a big pry bar and block of wood to coax the gas loaded shocks onto their mounts.
Replaced the front struts, was a little bit of a cat fight since I opted to re-use the OEM coil springs. Had to use my old friend, a pretty much worn out coil spring compressor. Pac now driving like new!
chiper1
Jul 14, 2017 07:54 AM
hanoverfist
Mar 5, 2012 10:40 AM
rogers29
Aug 4, 2010 01:23 PM
DaILLestWun
Jul 12, 2007 09:04 AM
