2004 Pacifica Front blower not working
Old Jul 25, 2013 | 03:45 PM
Cardsmall's Avatar
Default 2004 Pacifica Front blower not working
The other day pulling out of the parking lot my front blower just quit. No settings work. I've switched relays and checked for power at the fuse. I put a test light on the blower motor itself I have power, but whats odd when the blower is connected to the resistor I have power at both the positive side and negative side of the cable. Not sure if that's normal or not. pulled the motor and connected it to a battery and it ran at full speed. Checked the connections at the resistor with the blower disconnected and the positive side has power and the negative doesn't but when blower is connected my test light lights up at both connections. What do you guys think? Thanks! Any help would be appreciated I'm not good at diagnosing electrical systems at all.
Old Jul 25, 2013 | 04:42 PM
Try replacing the resistor block.
Old Jul 25, 2013 | 07:44 PM
Cardsmall's Avatar
Yeah I thought that was originally the problem but I thought if the resistor went out the fan could still run on high since it's suppose to bypass the resistor all together. Does anyone else have any insight into that? I just don't wanna go buying parts to diagnose the problem because the local auto parts store here doesn't let you return opened electrical parts.
Old Jul 25, 2013 | 09:32 PM
The whole thing can burn out and not transmit any current. The way it's wired is that the line coming from the blower motor is hot and the current goes through the various resistors to ground. Try jumping across the black wire on the block to any of the others, then try switching the fan control to see if you get any speed to work. If so, then the block is bad and will need to be replaced.
Old Jul 25, 2013 | 11:50 PM
kick the motor see if it comes back on then
Old Sep 10, 2013 | 06:25 AM
Seun Tayo Fadipe's Avatar
have you been able to fix this issue? I believe I have the same problem. Lucky I was able to purchase a power module and return it after I tested it and it wasn't the solution.
Old Jan 28, 2014 | 10:19 AM
Mr goodie's Avatar
I have the same problem also wht works I really need the blower to work I checked the fuse there good and I also used a 12v battery on the blower motor and it work and also replaced the resistor module I need help and it cold outside
Old Jan 29, 2014 | 06:13 AM
Default Fixed
I approached the problem with 2 solutions. I first bought the blower resistor and that didn't fix the problem, so I bought a new blower motor. Both items are located in the same area but the cage that covers the blower motor had a screw in the back that took me 2 days to finally figure out with a long flexible nut driver and a small magnet inside of it. Replaced both and everything works perfect. Am glad it worked because the winter has been horrible. I hope this helps other people
Old Feb 23, 2014 | 07:36 AM
cirrus98's Avatar
My fan stoppped working completly. Turns out the Blower motor was dead. From what I heard, if the resistor is "bad", the fan speed will blow on high only. So given that info, I went straight for the blower motor and voila.
steveatpa
Mar 8, 2012 01:06 PM
rastoma
Jul 7, 2009 07:41 PM
dbremer37
Nov 19, 2008 12:43 PM
beamond
Jun 2, 2008 09:01 PM
harryvil
Jul 30, 2007 05:38 AM
