2005 Pacifica. Tried to jump, car now totally dead.
Old May 27, 2012 | 12:16 PM
Trinten's Avatar
Default 2005 Pacifica. Tried to jump, car now totally dead.
Hi guys.
The battery went dead. Got a friends car over, hooked up the jumper cables. Pacifica had power (courtesy lights turned on, mileage on dash displayed, clock was running).
Gave it a few minutes to build up a little bit of a charge. Turned the key. There was a single click and then EVERYTHING went dark again. No lights, no clock, no *nothing*.
Got back out, re-checked all the cable connections -- still no power.
Shut down the other car, unhooked the cables. Checked all the fuses under the hood - all good (damn tough to get those tiny fuses out!!). Obviously no way to check the relays, though.
Any thoughts or suggestions on what happened?
This is a bit urgent, racing the clock somewhat. Thank you!
Old May 27, 2012 | 02:03 PM
replace the battery
Old May 27, 2012 | 03:56 PM
Trinten's Avatar
Thank you for the suggestion,
I didn't consider it because the battery is less than 2 years old. So even when another car is hooked up and supplying power to the vehicle, a bad battery can prevent everything in the car from getting power?
I only ask because I've never seen that before.
Thanks again!
Old May 27, 2012 | 05:52 PM
Thundercraft's Avatar
a battery with an internal short will kill things quick.... all the jumping in the world won't help you.
Old May 27, 2012 | 08:10 PM
Trinten's Avatar
Default Thanks guys!
Well I went ahead and disconnected the battery, and hooked up the battery from the donor car... sure enough, everything lit back up.
Definitely a learning experience for me, I was thinking the electrical system had just taken a dive!
Sadly now... when I try to start it, it's just a very rapid metallic clicking from under the car. So I think the starter needs to be replaced next.
Thanks to both of you!
Old May 27, 2012 | 11:25 PM
is your donor car battery crap? that is a weak battery with the fast clicking.
Again replace the battery with a GOOD one from the store.
Old May 28, 2012 | 08:46 AM
Trinten's Avatar
Thanks again for the info!
No, it's a good battery, BUT it might not have had a solid/good connection - which fits.
I'm just hesitant to buy a battery for it right now and find out it doesn't work. I'll give it a shot! Thanks!
Old May 28, 2012 | 01:17 PM
replace the battery
Old May 29, 2012 | 05:15 PM
Trinten's Avatar
Hey guys,
just wanted to hop back in and say thanks. Battery replaced and everything worked! I'll be honest, I was shocked, I've never seen that kind of behavior before - learn something everyday!!
You guys probably saved me a tow and paying someone to do a diagnostic on top of the simple battery swap. Thanks again!!
Old May 29, 2012 | 08:13 PM
Glad it worked out in the end.
Something so simple as a battery causing so much grief.....
Chrysler Forum Editor
Dec 14, 2013 06:01 AM
FlyBeats7
Jan 9, 2011 09:47 AM
aftab
May 9, 2010 03:31 AM
ag84
Jun 5, 2009 09:02 PM
